Thread: Component Cable Problem... |
New member Username: Myththesandman
Post Number: 1 Registered: Feb-06
| Posted on Wednesday, February 22, 2006 - 07:12 pm: |
i am trying to connect these component cables to my new maganavox 32 lcd screen that came with my dvd/surround system to the back of my lcd...not the standard..the component cables...now...i connect them into the component spot on the back of the tv...my 360 is in the hd spot on the bottom of the tv...all of the colors have been triple checked for the right slot color...so that is all good...the problem with this do you ask...i get a picture on screen...but it's red...the whole picture is a pinkish red...can someone help me? |
Gold Member Username: Samijubal
Post Number: 2350 Registered: Jul-04
| Posted on Wednesday, February 22, 2006 - 08:13 pm: |
Bad cable? |
New member Username: Soquij
Post Number: 4 Registered: Sep-04
| Posted on Wednesday, September 06, 2006 - 04:28 pm: |
Hi I'm having a similar problem right now. Did you ever solve the problem. Was it a bad cable? |
Platinum Member Username: Project6
Post Number: 10681 Registered: Dec-03
| Posted on Wednesday, September 06, 2006 - 06:32 pm: |
That is definitely a bad cable, when not all the leads are working properly. Get a working cable or at least try out one that you know is working properly. A dominant color means that the other channels are not being fed in. I hope he solved the problem since February. Not a lot of this posters ever come back after they get what they need. |
Post Number: 5 Registered: Sep-04
| Posted on Thursday, September 07, 2006 - 02:37 pm: |
Thanks for the answer, I'll test with a working cable. |
