Thread: ANOTHER DUMB QUESTION |
bhfdyfif Unregistered guest |
| Posted on Tuesday, February 14, 2006 - 06:45 pm: |
I have been looking at component cables online and some at long length is pretty cheap. Does it make much of a difference if it is made from rg59? Or what is the main difference to look for between the cheap and the expensive, thx |
bildodo Unregistered guest |
| Posted on Tuesday, February 14, 2006 - 08:30 pm: |
maybe someone can use these as an example, ty http://cgi.ebay.ca/100FT-5-RCA-Component-Video-Cable-HDTV-DVD-RG-59-u_W0QQitemZ5 866787990QQcategoryZ14965QQtcZphotoQQcmdZViewItem |
Post Number: 5732 Registered: Dec-03
| Posted on Tuesday, February 14, 2006 - 11:59 pm: |
Read on http://www.audioholics.com/techtips/audioprinciples/cables.htm |
dfgdfdf Unregistered guest |
| Posted on Wednesday, February 15, 2006 - 08:59 am: |
Still wondering if rg59 is total crap or if the norm is to get rg6 or higher. |
Gold Member Username: Samijubal
Post Number: 2307 Registered: Jul-04
| Posted on Wednesday, February 15, 2006 - 03:08 pm: |
Yes, RG59 is crap, RG6 is far better for slightly more money. Look at an RG59 cable and an RG6 cable, the center conductor is a lot thicker on RG6, the shielding is better too. |
