Home > Message Board > Accessories > Cables > Archive through March 25, 2006 > Connecting my PS2 to my Projector - C...
Author Thread: Connecting my PS2 to my Projector - Component to VGA connection??
Projector Madness
I just purchased the OPTOMA EP739 and have been using it as my current television (hooking HD cable through DVI into the projector), and getting a very nice looking 92" picture. When I hook my PS2 through my projector, I have to use composite video because there are no component connections.
At the top of this page
http://www.optomausa.com/store_productdetail.asp?product_subcategory=13&productc ategory=Cables&offset=5
(copy and paste link)
there is a FEMALE COMPONENT to MALE VGA connector.
My projector has a VGA input which I have used with my computer before, and supplies a nice picture. Do you think there will be a drastic increase on quality in resolution by running my PS2 through component into that VGA adapter into the Projector, as opposed to keeping the current composite setup? Will I be keeping the quality of component after passing through to VGA?
Home > Message Board > Accessories > Cables > Archive through March 25, 2006 > Connecting my PS2 to my Projector - C... [ « Previous ] [ Next » ]
