Thread: Splitting tv signal |
michael n Unregistered guest |
| Posted on Tuesday, January 10, 2006 - 03:52 am: |
Hi, I'm looking at buying a tv tuner for my computer. I need to connect the antenna in the roof. At the moment I have 2 tv's with very good reception, which share the signal. If I was to buy a connector that split the signal in 3, would I notice a drop in quality? Although I have absolutely no idea about signal strength stuff, if I can split the signal in two with no loss in quality- shouldn't I be able to split it in three with little quality loss ? Thanks very much |
Bronze Member Username: Coreyh6987
J-Town,
NC
Post Number: 26 Registered: Feb-05
| Posted on Saturday, March 25, 2006 - 10:23 pm: |
No you wouldnt notice loss in quality. They do make 4 way splitters for you to use. If you had more than 6 tvs onto one antenna then thats when the loss comes in and they make signal boosters for that.... |
Bronze Member Username: Willieman
PR
Post Number: 75 Registered: Jun-06
| Posted on Monday, June 05, 2006 - 04:04 pm: |
get an additional box |
New member Username: Filetester
Deep down,
Up there
Post Number: 2 Registered: Oct-06
| Posted on Sunday, October 15, 2006 - 06:22 am: |
You can buy a dual lnb and a 4in 1 out switch. i got it from www.ftavip.com it works good for me. Good luck! |
