Home > Message Board > Accessories > Remote Controls > Can't find a replacement remote
Author Thread: Can't find a replacement remote
I have a Haier 13" TV/DVD combo, but the remote is lost. I bought a universal remote, but it is not compatible. I can't seem to find a universal that lists this brand. The only replacement remote I can find is $52.00, but I only paid about $100.00 for the TV new. Will a learning remote be compatible? If so is there a cheap one? Or better a cheap universal remote that will fit this TV?
Relevant Product Info
Username: Samijubal
Post Number: 2021
A learning remote will require the original to teach it. Get a One For All that's telephone upgradable. If it doesn't work, they can send the code over the phone. Universal remotes are limited with combos, it won't do all functions. Most combos are Funai. If you can't find a Haier code, try funai.
Thanks alot for the input. I really appreciate it!
Username: Sturge_01
Ponte Vedra Beach, Florida
Post Number: 9
Hey, have a look at http://www.salehooo.com if you are looking for some top wholesalers for these! Its worth a look if your serious about getting some in!
Username: Project6
Post Number: 6041
UploadUpload
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Accessories > Remote Controls > Can't find a replacement remote [ « Previous ] [ Next » ]
