Thread: Using surge/conditioner for on wall plasma |
New member Username: Dhead97
Post Number: 3 Registered: Dec-05
| Posted on Monday, December 26, 2005 - 09:47 am: |
This might seem silly, but Im looking at getting a 42" plasma that I was going to hang on my wall in my living room. The outlet on this wall also has an ac pump connected to it that produces a small amount of static in the CRT tv I currently own for a few seconds that I dont beleive would be too good for the plasma. I was going to run another dedicated power circuit to this wall from panel box which is no big deal. What Im wondering is if I hang the plasma on the wall how do I hook it to a surge supressor/conditioner??? Would I have to use a model like the Monster HTFS500 that is thin and can mount behind it? Im thinking about buying an audio cabinet and placing it below it for my equip and then having the audio/video cables run up through the wall. One thing I wasnt sure of is whether I should get something like the Monster that goes on the wall mount or if there was a way I could buy a bigger conditioner that I could hook my other components to also and somehow also hook the TV to. Ive read where its not recommended to run the AC power cord though a wall for the TV and really dont want to run it down the wall where I will see it. Can someone help me thats had this situation? This is my biggest hang up. I want it to look nice by being on wall but also would rather not spend almost $300 on that Monster HTFS500 and then have to get another for my other components if theres a way I can plug the TV into the one I get for the wall cabinet. Thanks dwayne |
Bronze Member Username: Plato
Woodbury,
NJ
Post Number: 30 Registered: Oct-05
| Posted on Tuesday, December 27, 2005 - 07:17 pm: |
Use a flat plastic conduit to run the Tv power cable down the wall and paint it the same color as the wall. You won't be able to see it, especially if you have a center channel in front of it. |
Post Number: 5 Registered: Dec-05
| Posted on Tuesday, December 27, 2005 - 07:32 pm: |
Ok, I didnt think about doing that. That would solve that problem. I could then just run the audio/video cables in the wall. Do they make center channels that mount on the wall? Otherwise I guess I could just sit it un whatever cabinet I decide to buy. |
Woodbury,
NJ
Post Number: 31 Registered: Oct-05
| Posted on Wednesday, December 28, 2005 - 06:19 pm: |
I have a Martin Logan center channel and have the option of mounting it on the wall, but IMO it looks better on a low profile cabinet. Good luck! |
