Home > Message Board > Accessories > Cables > Archive through March 25, 2006 > Help with Setup
Author Thread: Help with Setup
Username: Shmoolie
Hello all,
I just found your forum and it is very impressive. I'm sure you will be able to answer my questions.
I have a Comcast digital (non HD) receiver that receives its signal via coax from the outside (pretty normal). It has an S-video and a composite output. I have a Tivo which has an S-video and composite input AND also a component output. I have a TV (non-HD) that has all three inputs.
What would be the optimal connection for these? I know that component will provide the best quality video but if my cable receiver gets its signal via the coax and only has S-video and composite outputs would using component from the Tivo to the TV really matter?
Thanks for your help.
Username: Shmoolie
Isn't anyone going to answer?
Home > Message Board > Accessories > Cables > Archive through March 25, 2006 > Help with Setup [ « Previous ] [ Next » ]
