Home > Message Board > Accessories > Cables > Archive through March 25, 2006 > Component v Composite Cable Differenc...
Author Thread: Component v Composite Cable Difference???
I have three good quality composite cables. Is there any real reason I cannot use these three cables for a component hookup? A side by side comparison with a set of component cables shows no visible difference other than the color coding.
Thanks
There is a minimal difference. Component wires may have slightly better shielding on them, but the difference is not very noticeable.
Home > Message Board > Accessories > Cables > Archive through March 25, 2006 > Component v Composite Cable Differenc... [ « Previous ] [ Next » ]
