Home > Message Board > Accessories > Remote Controls > Need a remote that controls the cente...
Author Thread: Need a remote that controls the center channel mode (normal, wide, and phantom).
Dues anyone know of a reasonably priced (<$100)universal remote that is capable of controlling the center channel mode of a home theater receiver? I want to be able to switch between normal and phantom modes. None of the remotes I looked at are capable of doing this. I can't tranfer the signal to a learning remote because the original is dead. Thanks
*Does
Username: Samijubal
Post Number: 1790
Take your learning remote to someplace that sells your system and use their remote to teach your remote.
Username: Toddious
Orlando, FL
If you know anyone that has a pronto, you can have them download the codes from an IR database onto their pronto, and then you can learn them from there. Just an idea, Todd.
Username: Toddious
Orlando, FL
or if you know anyone with any other remote that is computer programmable (mx-850, mx950, tx-1000, mx-3000, etc)
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Accessories > Remote Controls > Need a remote that controls the cente... [ « Previous ] [ Next » ]
