Thread: Monster vs. AR vs. RadioShack |
New member Username: Jomomope
Post Number: 2 Registered: Apr-04
| Posted on Friday, April 16, 2004 - 04:52 pm: |
Hi, I have to buy component video cable for a sony HDTV with Onkyo A/V. Cables are expensive. I want to buy something that makes sense. Please, help. |
New member Username: Milou6
Post Number: 4 Registered: Apr-04
| Posted on Thursday, June 17, 2004 - 08:58 am: |
Personally, I like the Acoustic Research, although I own some Monster Cables as well. Also, try running the component cable directly from the source (DVD or cable box, etc) to the TV, rather than through your receiver -- this will give you the cleanest connection and save you a cable. |
