Thread: Best Place(s) to Buy Quality A/V Cables Is? |
New member Username: Tombrooklyn
Post Number: 1 Registered: Oct-05
| Posted on Tuesday, October 04, 2005 - 01:53 am: |
Who offers the best prices on good quality A/V cables? |
Silver Member Username: Hd_fanatic
Boise,
ID
Post Number: 160 Registered: May-05
| Posted on Friday, October 07, 2005 - 01:00 am: |
Check out these sites: http://bettercables.com/ If these seem a bit too expensive, look here - http://www.knukonceptz.com/index.cfm I bought some component video and RCA cables from Knukonceptz and the picture looks as good as my monster cables did. I had to buy some longer cables and didn't want to spend an arm and a leg. I have always been a believer that you had to spend alot of money for good cables, so I was skeptical at first. I was pleasantly surprised when I plugged them in. |
Gold Member Username: Samijubal
Post Number: 1711 Registered: Jul-04
| Posted on Saturday, October 08, 2005 - 06:23 pm: |
E-bay has some pretty good deals on cables if you can tell good from bad, there's a lot of cheap junk too. |
Post Number: 2 Registered: Oct-05
| Posted on Monday, November 07, 2005 - 11:25 am: |
Thanks for the leads. Tom |
Steve Ferns Unregistered guest |
| Posted on Monday, November 28, 2005 - 02:11 am: |
Still the best for the money: http://www.aviccable.com/ |
New member Username: Waynesnside
Wisconsin
Post Number: 6 Registered: Nov-06
| Posted on Friday, November 03, 2006 - 09:26 am: |
try monoprice.com I've gotten 4 cables from them so far with no problems. 2 HDMIs 1 set components 1 digital optical |
New member Username: Arande2
Post Number: 9 Registered: Dec-06
| Posted on Tuesday, December 05, 2006 - 10:58 pm: |
I recommend straightwire cables. They've done wonders for my system. I use them in all my interconnects and cables. www.straightwire.com |
