Thread: Do I really NEED a UPS/conditioner/etc ??? |
Bronze Member Username: Kevinp
Post Number: 19 Registered: Aug-05
| Posted on Friday, September 16, 2005 - 02:29 pm: |
My current setup is a standard 36" CRT, DVD player, 500 watt surround sound system & digital cable box. I'm just using one of those $10-$20 power surges and haven't had any problems or issues in years. My NEW setup in a few weeks will be: 42" LCD TV, 500 watt surround system, CableCard (no box) & Xbox game system. I'm NOT even considering a $400 UPS or whatever they are called. I don't have a problem with power outages in my area nor do I have any flicker or static when A/C or refrigerator starts running. BUT I didn't know if those power strips by Monster, etc. that are in the $100-$200 range supposdly "cleans" noise from your line really does anything. I notice you can also plug the coaxial cable into it before going into your TV. I will also have a wireless cable modem near this well, so didn't know if there was any issues. Finally what is the minimum "JOULES" I should look for, considering any of this is "neccesary". Thanks :-) |
New member Username: Gtf
Moriches,
NY
Post Number: 9 Registered: Feb-05
| Posted on Tuesday, November 08, 2005 - 08:15 pm: |
http://www.elect-spec.com/acprot2.htm#Laboratory This company sells no nonsence power filtering equipment. Email Frank with your concerns. No BS products. So forget about cryo this or cryo that. No bright colors or flashing lights either. GTF |
New member Username: Stevedohar
Houston,
TX
Post Number: 2 Registered: Dec-05
| Posted on Sunday, December 11, 2005 - 08:53 am: |
If you have that much invested in electronics. I advise you to get an on line UPS. It only takes one good spike to blow a lot of equipment up. A good quality UPS can probably end up making your electronics run better and longer by not stressing your equipment with smaller spikes and brownouts. |
New member Username: Southern_bass
Jacksonville,
Florida
U.S.
Post Number: 3 Registered: Dec-05
| Posted on Monday, December 12, 2005 - 05:29 pm: |
yes |
New member Username: Pokerwhiz12
Post Number: 4 Registered: Mar-06
| Posted on Monday, March 20, 2006 - 01:37 am: |
thats great..thanks for the info |
| Posted on Monday, March 20, 2006 - 01:38 am: |
Post Number: 5 Registered: Mar-06
