Home > Message Board > Accessories > Power Conditioners > Need a little help
Author Thread: Need a little help
Username: Spittin2rock
Post Number: 118
this really isn't an audio question but I have a 98 explorer and my door triggering device isn't working for the driver side. Is there a fuse or something I need to look at?
Relevant Product Info
Username: Project6
Post Number: 5242
Username: Pokerwhiz12
yea check the fuses
or the wiring may have burnt out somewhere between the fuse and your door triggering device
if the fuses are all in order then try removing the side panels from your door and you should see all the wires
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Accessories > Power Conditioners > Need a little help [ « Previous ] [ Next » ]
