Thread: My Custom Studio Speaker Stands! with led light! |
New member Username: Tigzstudio
Post Number: 2 Registered: Aug-05
| Posted on Friday, August 19, 2005 - 04:35 am: |
Hey there, I just finished my DIY from scratch led speaker stands, (bondo, and glue still drying)..! pics: image 1 image 2 ingrediants: 1x MDF board shelf 5'x.5"x1'(1.99) 1x hammered metal spray paint (rustoleum) 1x gloss white spray paint (krylon) 4x 6" pvc pipe (.69 cents each) 2x white led super bright (1 per stand) ($2.00) 1x custom cut plexi (frosted with sand paper) ($4.00) total cost ~ $24.00 tools used: sodder sodering iron circular saw drill sand paper (400, 1500, 1800) super glue bondo floor glue I need my desktop Paradigm Speakers to rise another 6" on my desk, however I didnt want to hunt for them in store, and have to spend 79 dollars for them! so i improvised. heh. the hardest part was the led/switch wiring The leds get power from my computer system ( i was thinkin bout using a battery 9v or 2 x AA, but it would only last 1 week, i want em on while my audiophile computer system is on! Also integrated a switch on each stand incase i want to turn em off. They get power via mini fan connecter (+5v). I used 5v white led. I used sleeving on the wiring from computer to speaker so it looks like hi-fi speaker cable. If you dont want the extra wire u can just remove the cable and it is flush at the base. The pics will be coming showing step by step process of build.. let me know what u think! thanks,
Silver Member Username: Joe_c
Atlanta,
GA
Post Number: 967 Registered: Mar-05
| Posted on Friday, August 19, 2005 - 07:07 pm: |
lets see it setup, looks pretty cool though. |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 5368 Registered: May-04
| Posted on Sunday, August 28, 2005 - 02:22 pm: |
Looks just like that '67 Impala with the lights under the chassis that I saw at the car show. |
Gold Member Username: Joe_c
Atlanta,
GA
Post Number: 1086 Registered: Mar-05
| Posted on Sunday, August 28, 2005 - 04:48 pm: |
Don't have to change the oil in these though. |
Dallas,
TX
Post Number: 5371 Registered: May-04
| Posted on Sunday, August 28, 2005 - 05:24 pm: |
Don't give him anymore ideas, j.c. |
