Thread: Bi-wire |
| Posted on Monday, March 22, 2004 - 11:34 pm: |
Can you bi-wire regular speakers and would there be any advantage. Like run two speaker wires to each speaker. |
| Posted on Tuesday, April 13, 2004 - 09:37 pm: |
I dont think this would provide any real benefit. All the bi-wiring would do is reduce the resistance from amp to speaker, which is not really significant as long as the cables are of suitable gauge. |
Bronze Member Username: Lockaudio801
Post Number: 51 Registered: Apr-04
| Posted on Wednesday, April 14, 2004 - 04:32 am: |
Joe C. Provided your speaker has dual binding post for low and high frequency bi-wiring em` to your amp can mean an audible difference to the sound you hear.Reducing the resistance in itself is a marked improvement however all these things would depend on your hearing faculties. Best way to find out of course if you try it I say! Good Luck |
Bronze Member Username: Robertinchico
Post Number: 62 Registered: Apr-04
| Posted on Friday, May 07, 2004 - 09:10 pm: |
If you have a speaker with a bi-wireable terminal facility, it's there for a reason. Dont "double-up" cables unless you have FOUR connectors on the back of the speaker. People who state bi-wiring doesn't "do anything" or "it's too expensive" or drag up that stupid "resistance increases" babble or state their grandpa didn't bi-wire his Model T haven't tried bi-wiring a good speaker with good cables |
Silver Member Username: Kegger
MICHIGAN
Post Number: 240 Registered: Dec-03
| Posted on Saturday, May 08, 2004 - 02:32 am: |
chicobiker is right on there if your speakers are biwireable by all means do it. but if they have single conections don't. if the speakers are biwireable i usually try to pick up a second amp and biamp them.
