Home > Message Board > Accessories > Remote Controls > All in One remote
Author Thread: All in One remote
My all in one remote works with my Onkyo receiver (volume, inputs switching, ect.) but it won't turn it off? Anyone know why?
The code they give for Onkyo is 0135, is there another one?
Thanks...
Relevant Product Info
Try this: 2660 or 2662 or 2678
Username: Go77306
what is the model of your all in one? if it is JP1 compatible, you can use a JP1 cable to program it. Here is a list of some jp1 compatible remotes:
http://www.diygadget.com/jp1/remotechart.php
I used code 0060 ( a samsung code ) for the Akai CFT2791 TV and it works! Akai remote codes are HARD to find, at least ones that work. Hope it works for you.
Username: Laniers3jm
Mcminnville, Tn
United states
I have an akai 32'lcd tv/dvd combo lct3201td wondering if anyone had the remote code for a one for all remote
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Accessories > Remote Controls > All in One remote [ « Previous ] [ Next » ]
