Thread: Long length HDMI cables....ah which ones? |
New member Username: C2sox
Garden Grove,
CA
Post Number: 1 Registered: Jun-05
| Posted on Thursday, June 16, 2005 - 08:55 pm: |
There seems to be quite a few choices with varying price ranges. So far I've seen RAM, Key Digital, DTrovision, Gefen and Ultralink. Can anyone recommend a 50ft cable length that achieves 1080p? Would I be better off using a repeater/extender? WHat have you guys used and can anyone share their experiences? Thanks in advance, Al |
| Posted on Monday, November 28, 2005 - 04:52 pm: |
All of these manufacturers claim to have a 1080p cable at longer lengths but I've seen them all fail at 30ft +. THe best setup I have seen is IXOS, they have a 50ft cable but they recomend using their booster to assure you get a full 1080p at 50ft. Their # is 800-826-4697. Don't try their website it sucks and doesn't even list their HDMI and DVI cables. |
New member Username: Jeffsu
Norcross,
Ga
Usa
Post Number: 5 Registered: Oct-05
| Posted on Sunday, December 18, 2005 - 04:58 pm: |
Here is a HDMI extender repeater:http://www.octavainc.com/HDMI%20extender.htmfor those looking for help in projector installs. It cleans up and boosts the TMDS signal after a long cable run. It includes a power adapter for powering. For long HDMI cables, it will be necessary to inject the power at the HDMI extender repeater due to the voltage drop across the cable. www.octavainc.com
