Home > Message Board > Accessories > Remote Controls > Durabrand romete control codes
Author Thread: Durabrand romete control codes
Username: Routrae
hello, i am looking for durabrand universal remote control codes. couldnt find them anywhere on the net. i need a code for jvc vcr, as well as insructions on how to program it.
all help is appriciated.
Relevant Product Info
Vitt
Hey John, I don't know if they'll work, but I was able to find JVC VCR codes for Durabrand TV, which are 02, 25, 58. If you are programming a Durabrand to another remote, codes 520 or 115 may work. I hope this helps
I have a durabrand tv/vcr combo with no remote, i bought a GE universal remote and cant find the codes can someone help?
rgeezy
yall know if this duranbrand tv model works on "dish networks" 4 device remotes???????????
neomnimon
I have a durabrand 20" tv #BH2004D and I need the codes for my rca d770 remote e-mail at neomnimon@yahoo.com
I have a durabrand 20" TV #bh2004D and I need the codes for my One For All Remote. URC3021w.
email at bgraham1964@yahoo.com
Username: Robinraz
If you've purchased a universal remote and have a durabrand TV, try using the Orion codes. I found this on another website and it worked.
Best of luck,
Robin
Username: Nightscape
hi i have a one for all remote "rc300pb00" and i have a durabrand tv model number bh20004d. i was trying to find the code to work this tv. someone from another web site gave this as being the code list for the remote
http://www.hifi-remote.com/manuals/manual.shtml?URC-4730
none of the orion codes worked and it did not have a code for the durabrand tv.
however when i tried the code for the magnavox tv's and the one that worked was the first one on the magnavox line "0054"
dont know if this will help anyone, thought i would share.
Username: Jdt2982
IL
I am looking for the tv code for a durabrand DU2701B using an VCR Plus Universal Remote #B27900, or an RCA Universal Guide Plus Gemstar #F27650 which goes with an RCA TV. Is there anyone that can help me?
Username: Doohickey
Think I may have your answer. Durabrand is made to sell at the box stores. The same company that makes it also makes Symphonic, Sylvania, Emerson, Superscan, Misakai, Funai, and ESA that I know of. My son has the Durabrand DV1901 and I found that a code for Emerson worked fine. Guess you never know which components are in the "Box". Might try the ones listed for the above.
Username: Carlreesen
Cornell, Wisconsin
Usa
yea hello i have a question i just bought a durabrand and i have a rca universal remote and i couldn't find any codes for my remote at all can anybody help
Username: Najlaali
East Orange, NJ
For durabrand televisions, try code 053. It worked for my television.
Username: Cx3200
i have a durabrand tv 2127N And i cannot get the tv off the key screen: what number & combination of buttons do i use:
Username: Yusaf
I have a Durabrand tv 2127N And i cannot get the tv off the key screen "---" then "///". what number & combination of buttons do i use to reset/ unlock?
help please!
Username: Shortdude
Salt Lake, Utah
United States
I have a durabrand BH2004D 20" tv Bought second hand and bought a Universal remote UR3U-MDVR-CHD2 and need a code that works any help email madsen@xisssmion.com
Username: Shortdude
Salt Lake, Utah
United States
UPDATE, I used the code for a sylvania and it worked, well sort of, I can turn the tv on and off but nothing else--any suggestions email madsen@xmission.com
Username: Bhuck
Poseyville, IN
I found a replacement remote for my Durabrand TV that works really well, (will even switch to game mode), at replacement remotes.com, for a reasonable price. Just type in the remote you are looking for on the search bar at the top of their website.
Username: Msdfatboys
Tahoka, Texas
Hello, I am new to this board, and hopefully my advice will help someone who has a Duraband TV. My husband lost the remote to my 20 inch TV. I got mad, and bought a universal remote for it. I tried the code search method several times. The book didn't have my brand mentioned in it. I got mad, and came to this website last night. I tried using the Funai codes, and the Orion codes listed in the book. Finally the last code for the Orion TV worked the remote. Thank you so much for the info! So if anyone is having problems with their universal remote for the Duraband TV, use the Orion codes. They helped me a lot.
Username: Snakebite0316
hi anyone know the key code on a2127n tv
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Accessories > Remote Controls > Durabrand romete control codes [ « Previous ] [ Next » ]
