Thread: Review of Acoustic Research 6' MS291 ? |
New member Username: Gazix
Post Number: 1 Registered: 02-2004
| Posted on Monday, February 23, 2004 - 12:53 pm: |
Where can I find reviews, or opinions of these component video cables. I found them on ebay for cheap, but wondering if there worth it or buy a $45 set locally? |
New member Username: Dorkboy
Post Number: 1 Registered: 03-2004
| Posted on Monday, March 01, 2004 - 11:11 pm: |
I have them and I love them. I have only compared them to cheaper junk cables, and they are great. I recommend them. |
Scootusa01 Unregistered guest |
| Posted on Tuesday, March 02, 2004 - 09:26 am: |
I have them as well and have been more than pleased. |
New member Username: Avman
Post Number: 7 Registered: 03-2004
| Posted on Wednesday, March 03, 2004 - 03:45 am: |
New flash Radio Shake and RCA co just bought them out. there not bad and better then most, but ther are lots more types that are out there that would be better. |
Bronze Member Username: Buckeyeshine
Post Number: 28 Registered: Feb 23, 2004
| Posted on Wednesday, March 03, 2004 - 08:16 am: |
accessories4less.com has excellent deals on Acoustic Research cables. Partsexpress.com is also another good source. I have heard Dayton is another good cable reasonably priced. I just purchased AR composite audio cables but I stepped up a bit and went with Audioquest for my component videos. I haven't compared them to AR so can't speak for the side by side benefits if any. Audioquest makes some very good cables with a broad pricerange from those on a budget to very high end stuff. ABT Electronics and HCM Audio both carry AQ on-line. |
| Posted on Monday, May 31, 2004 - 11:40 am: |
Could I have somehow incorrectly installed these cables? The dvd picture looks no different than with the default a/v cable that came with the player. I had the a/v cables plugged into the front jack of my tv, watched a bit of a movie, then flipped video to the component and plugged the other ends of the cables into the component jack of the dvd player. It's not an hdtv, but that shouldn't matter should it? (no progressive scan either) Its gazix, for some reason I keep getting errors when trying to post |
| Posted on Monday, May 31, 2004 - 06:02 pm: |
Acoustics Research Component Cable consumer reviews linked from this site: http://www.ecoustics.com/r.php?search=Acoustic+Research+component |
| Posted on Thursday, June 03, 2004 - 10:30 am: |
How does that help me at all? There is only 2 reviews of these same cables and one says the same thing I am wondering about. Sorry if this post comes up twice, I'm having issues with this site not letting me log in and errors when trying to post |
