Thread: I got a question |
| Posted on Sunday, February 22, 2004 - 06:19 am: |
Umm are the component cables same as the composite cables? Say if I used a composite cable with video, L audio and R audio as a component video cable would it be the same quality? If not what’s the difference? |
New member Username: Johnman
Post Number: 3 Registered: 02-2004
| Posted on Monday, February 23, 2004 - 04:23 pm: |
They are identical and interchangable. |
| Posted on Friday, February 27, 2004 - 05:59 am: |
There are arguments that coaxial is 75ohms while audio composite may just be 50ohms. 50 ohms is normally OK for sounds but insufficient for picture quality. I haven't read any technical document about this comparison. Has anyone read one? |
New member Username: Avman
Post Number: 8 Registered: 03-2004
| Posted on Wednesday, March 03, 2004 - 03:54 am: |
No they are not the same He is right you need 75ohms to get the right picture qulity, They completly diffrent constructions. |
Bronze Member Username: Buckeyeshine
Post Number: 27 Registered: Feb 23, 2004
| Posted on Wednesday, March 03, 2004 - 08:10 am: |
Gabriel is absolutely right. Composite video cables are NOT interchangeable w/ Component Video cables. |
