Home > Message Board > Accessories > AV Furniture > Speaker brackets
Author Thread: Speaker brackets
Username: Preece
Iknow it isnt ideal but i need some speaker brackets to affix my wharefdale 9.1 speakers to the wall. am having trouble finding some. Have been told wharefdale dont have any yet.
G_Trump
There are approximately 1 trilion (more or less) speaker brackets availble. Check out Omni Mount as one example, as well as Target. Any competant retailer should have a couple to choose from. Good luck!
You might want to consider the B-TECH BT77, this is a wall mount bracket designed for bookshelf speakers. The brackets will tilt and rotate left and right. The speaker is held with a side clamping arrangement which works very well. I have been using them for the last 5 years on my B&W speakers. You can find info and install instruction at www.btech-usa.com
Username: Monstercable
Post Number: 21
HAVE U GOT THE SPEAKER BRACKET? colin?
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Accessories > AV Furniture > Speaker brackets [ « Previous ] [ Next » ]
