Home > Message Board > Accessories > Antennas > 2 antennas on the roof?
Author Thread: 2 antennas on the roof?
Username: Zeekh
Hi I'm new here. Just had a quick question. I was thinking about putting 2 anteenas on my roof to pick up a more OTA broadcast stations. I will probably use the same mast to mount them. Will using 2 antennas adversely effect my picture quality in anyway? Thanks Tim
Username: Captain
Post Number: 56
testing
1
2
3
Username: Captain
Post Number: 57
Username: Captain
Post Number: 58
test
Username: Captain
Post Number: 59
test1
Username: Captain
Post Number: 60
Username: Jwill
If they are pointing in different directions then you can use 2 sockets on the receiver, or combine them into one lead with a diplexer. All you need is to ensure that they are separated vertically by a distance equal to a minimum of a half a wavelength.
If you are pointing both in the same direction they can be joined together to increase signal with a phasing harness, which requires some maths to get it to work properly. They still need the vertical separation to work properly.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Accessories > Antennas > 2 antennas on the roof? [ « Previous ] [ Next » ]
