Home > Message Board > Accessories > Antennas > About tv signal boosters
Author Thread: About tv signal boosters
Username: James_the_god
Doncaster, South Yorkshire
England
Post Number: 52
Can you boost an already boosted signal????
I already have a booster downstairs for the main tv and have a wire transmiting the signal upstairs to my bedroom. I have channels 1-5 normal tv and channel 6 as sky, which is whatever sky channel is on downstairs.
However, I was wondering if adding a booster to my tv upstairs would actually work??
Username: Ke5aqn
Shawnee, OK
Post Number: 97
you may want to try one but, the "booster" (re:amp) will boost everything on the line so point is if has interference on it it could boost it as well. You would want to put the booster at the signal source hopefully before the interference gets into the cable downstairs If I followed your system right.
hope that helps
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Accessories > Antennas > About tv signal boosters [ « Previous ] [ Next » ]
