Thread: Remote Controle Durabrand (Walmart) |
New member Username: Carl1967
Post Number: 2 Registered: Dec-04
| Posted on Friday, December 10, 2004 - 04:33 am: |
for Durabrand (walmart)replacement remote control, try Emerson's tv code #0463 worked on my Shaw digital tv remote control!! |
New member Username: 16jetson
Collingwood,
Ontario
Post Number: 1 Registered: Sep-05
| Posted on Friday, September 30, 2005 - 02:36 am: |
universal remote by RCA code number RCU400, will work with a durabrand t.v. |
Unregistered guest |
| Posted on Friday, September 30, 2005 - 07:21 am: |
I purchased a Durabrand 13" color tv made by Haier from Walmart last nite. I called the support # listed in the manual and was told that there is no code. I realize that they maybe a code does exist but I am not going to start with 0001 and work my way up towards 9999 until I find it. It is easier to return it and buy a tv with a published code. I have found 4 or 5 companies that produce Durabrand products. I wonder who owns the name or how that works? |
New member Username: Theviking
Cut Off,
La
Post Number: 1 Registered: Apr-06
| Posted on Wednesday, April 19, 2006 - 07:05 pm: |
I have a 24" Durabrand TV and an "All for One" Universal remote. The codes i have found are useless!! If anyone has any information that can help PLEASE EMAIL ME!!! theviking@myviscom.com Thank you!! |
New member Username: Poker800
Post Number: 1 Registered: Jun-06
| Posted on Friday, June 16, 2006 - 09:31 pm: |
i lost a remote control to a durabrand ht-395 surround sound box and i bouht a universal remote and it dident come compactable with the box |
New member Username: Abpkf
Post Number: 1 Registered: Aug-06
| Posted on Friday, August 11, 2006 - 11:58 am: |
I have a 27'' durabrand tv but i dont have the manual. So if anyone can possibly help me with finding the code to an emerson vcr it would be greatly appreciated. Also, i need to know the way to actually program it because i dont have the manual and dont know which buttons to press or in what order. Thanks in advance. |
