Home > Message Board > Accessories > Remote Controls > Intellicontrol or RTI
Author Thread: Intellicontrol or RTI
terry sals
Hi - my dealer is oferring either remote contol system at the same cost. Never had a control system before........any suggestions ? thanx
Relevant Product Info
G_Trump
What exactly (more or less!) do you plan on controlling? Both companies and others offer some excellent products but although there is some overlap, each has an appropriate client in mind.
glackowitz
I would go with the RTI remote as it has the LCD screen (if your getting the T2+) and will allow favorite channel icons and local radio stations with Freq and name in the LCD. will allow CD changer control...might take a bit more work as you will have to list each cd in each slot and dealer will have to program it in..could take time, time =$$. If they are offering the RTI see which one they are including the T1 or the T2+.
Here is a link to the RTI Site: www.rticorp.com
I think the RTI is less cumbersome and more user friendly
Hope that helps
Glackowitz
I am looking for someone in the Boca Raton, Florida area who works on the Niles Intellicontrol system. I cannot seem to find anyone who will work on a system that they did not install. Please contact me at my email address.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Accessories > Remote Controls > Intellicontrol or RTI [ « Previous ] [ Next » ]
