Thread: Star Choice IRC442 Remote Code for Durabrand dbtv1020 |
New member Username: Mauler
Post Number: 1 Registered: 01-2004
| Posted on Wednesday, January 14, 2004 - 10:59 pm: |
I have a 19" Durabrand DBTV1020 Television. I can not find the code for it in the Star Choice manual, and I have sat down for over an hour searching through the remote and still cannot find it. Is there anyone who could give me the code, I would greatly apreciate it. vav_mauler@hotmail.com |
Relevant Product Info
jeffstewart Unregistered guest |
| Posted on Friday, November 05, 2004 - 12:07 pm: |
ok..i have a uni remote from cable provider. had to call the manufacturer about my durabrand t.v. guy said that they have to upgrade the remote, and thats the only solution..they would do it for free... hope that helps |
| Posted on Saturday, December 18, 2004 - 10:47 pm: |
I have a 19" Durabrand DU1901 TV. I can't find the code for my Echostar Satellite. I would greatly apreciate it. |
Cheap Buyer Unregistered guest |
| Posted on Friday, January 21, 2005 - 01:42 pm: |
THERE IS NO CODE FOR THE DURABRAND TV AT THIS TIME, SO SAYS THE MFG REP @ 877 337 3639. WOULD SUGGEST BUYERS WHO WANT CODES RETURN PRODUCT IN EXCHANGE FOR A NAMED BRAND. |
| Posted on Wednesday, March 16, 2005 - 08:17 pm: |
does anyone know the code for durabrand tv.ijust bought my son one in november and he messed up his control and now i cant get a remote to work with it any help appreciated email me at gamedic7700@yhaoo.com
| Posted on Saturday, April 16, 2005 - 04:25 am: |
recall all duraband telvisions due to no reliable back up remote avileable help us all find some help |
| Posted on Friday, April 22, 2005 - 01:43 am: |
CAN ANYONE HELP ME?I NEED THE CODE OR CODES FROM MY DURABRAND REMOTE TO THE CABLE BOX,ITS A SCIENTIFIC ATLANTA. |
New member Username: Martybridge
Post Number: 1 Registered: May-05
| Posted on Monday, May 23, 2005 - 05:25 pm: |
I have a Durabrand television with a bad remote. The model is BH2004D. There is no Universal remote that will work. The people at 877-337-3639 said I should send $20.00 to Higher America in New York and they will send me one. After getting all the responses above, I called Walmart. I suggested (rather strongly) they take Durabrand off their shelves. I have had a call from Walmarts merchandising dept. and am waiting on a call from the Buyer. I will boycott all Durabrand products until this is corrected. |
| Posted on Tuesday, June 07, 2005 - 12:57 am: |
after reading everyones complaint about there durabrand tv including the one i got. i have only one sollution. taking mine back and throwing threw the window. never buy tv's from walmart. |
| Posted on Saturday, June 11, 2005 - 09:03 pm: |
I just bought a Durabrand 1905 and set out to find the remote codes for it. Found this site and realized I'm obviously not alone. So I Just got off the phone with Durabrand reps who were no help.. I insisted on speaking to a manager who was also NO HELP, other than telling me that some of their products are purposely made to only function with the OEM remote! I'm taking the worthless piece of crap back to the store and never again buying that brand or any others associated with it. I suggest everyone boycott Durabrand, Their parent company Funai and all the other junk brands they make. http://www.funai-corp.com |
| Posted on Wednesday, June 29, 2005 - 02:57 pm: |
I have a durabrand BH2004D tv the remote from direct tv worked on it but i changed to dish and now i cant control it. if any one finds a code that works with a dish remote on the durabrand please tell me. |
| Posted on Wednesday, June 29, 2005 - 11:44 pm: |
I recently bought a Durabrand Television Model DU1901. My parents bought it for me for Christmas and then I moved out and did nothing more with it than but it in the box and plug it back in at my apartment. Now I have no sound or picture.. Any ideas before I take it to a service center? |
whiskybran Unregistered guest |
| Posted on Saturday, July 02, 2005 - 09:36 pm: |
Try the Orion code. It worked for me. |
froglady Unregistered guest |
| Posted on Saturday, July 02, 2005 - 10:41 pm: |
Thanks, the orion code 0493 worked for my 19". Good luck, I think you will need it. |
Post Number: 2 Registered: May-05
| Posted on Sunday, July 03, 2005 - 10:44 pm: |
I'm glad to hear that your remote works with the satelite. For those it does not work with, I have the name and e-mail [phone numbers] of people that count. I have been two months on a Durabrand BH2004D remote that I bought from Walmart. I have heard every excuse in the book. They still did not know me [although I sent in my warranty card] after all this time. I would like to suggest that people do some research. My television is represented by Haier America. This company is owned by Communist China. I wish I had known that when I was in the market. I hold Walmart responsible for buying this crap to begin with. If you want the address send me a line. martybridge@ev1.net |
| Posted on Saturday, July 16, 2005 - 06:23 pm: |
too everyone that is still using the durabrand remoted control that came with the tv. There is the answer right in front of everyone, if you look at the remote you will see a button that looks like -/--. that is the button that controls the channels. press that before you press a two digit number and it actually works. My son showed this to me when I asked him why I couldnt figure out the channel part of this.....DUH dont I feel dumb. |
| Posted on Tuesday, July 19, 2005 - 05:29 pm: |
I don't think the -/-- should make a difference on the power button do you? |
| Posted on Tuesday, August 09, 2005 - 06:36 pm: |
Hi all. I've been working on this remote problem too. If there are any numbers on the BH2004D original remote someone please post them and I'll see if I can locate a replacement remote or at least figure out who made it. Someone in a post says it's a Haier, but the picture on WalMart's site is an Orion set. There are a lot of manufacturers for Durabrand, but Orion and Funai are the most common. If you know what the original looked like go to www.newremotecontrol.com and look at the Funai and Orion remotes. If a physical match is found let me know and I'll try to verify that it puts out the right IR code.
| Posted on Sunday, August 14, 2005 - 01:51 am: |
numers inside remote for the BH2004D are RC0541/00 3139 238 08041 HTR-098 CC01 05444 B 004693 Hope this helps. Maybe if you find something you can send me an email to let me know where. Stormyscorpio78@yahoo.com |
Kelly Jo Unregistered guest |
| Posted on Tuesday, August 30, 2005 - 07:50 pm: |
Looking for remote code for a Durabrand DBTV1020, know it? Please send to: umecommunicate@mail.com |
| Posted on Wednesday, September 28, 2005 - 12:03 pm: |
I have a t.v DBTV2024PF. I can not find the code for the sub-brightness. plaese give me the code. I would greatly apreciate it. |
evertaker Unregistered guest |
| Posted on Thursday, September 29, 2005 - 09:19 pm: |
try 052. it worked for me.....good luck. durabrand.
eurojax Unregistered guest |
| Posted on Wednesday, October 12, 2005 - 08:35 am: |
Orion code 0463 worked for my 27" Duracrap. |
Brat4ever1 Unregistered guest |
| Posted on Thursday, October 13, 2005 - 10:44 am: |
I've bought two universal remotes to replace the Durabrand model. One said that it worked for Durabrand on the back of the package but when you open it up, no code in the book. I tried so many codes for the other one and nothing. I finally found 1-800-remotes and they have OEM's that you can purchase. They are not cheap. I ended up spending $48 with shipping charges. Now I just hope that it works when it gets here. I will NEVER buy another Durabrand product! |
Cheap_Freddy Unregistered guest |
| Posted on Thursday, October 13, 2005 - 08:06 pm: |
Try 0171 - it worked for my 27". I tried the Orion codes with no luck. The I tried the Funai ones and lucked out with the last one - 0171. |
New member Username: Jactor2k2
Dodge city,
Kansas
Usa
Post Number: 1 Registered: Oct-05
| Posted on Tuesday, October 25, 2005 - 06:21 am: |
help son has durabrand tv 19 inch does any universal remote work??????? have one for all searched for code for hours |
New member Username: Hunt167
Post Number: 1 Registered: Nov-05
| Posted on Sunday, November 06, 2005 - 11:38 pm: |
I have a RCA universal remote, (sold at Walmart) Sanyo code #1189 works on my Duraband TV |
| Posted on Sunday, November 13, 2005 - 01:31 pm: |
I was able to get a Jensen 4 way remote JR400 to work on my Durabrand 13 inch DWT 1304 using the search mode |
| Posted on Sunday, November 13, 2005 - 06:12 pm: |
i need acode for a durabrand |
Unhappy person Unregistered guest |
| Posted on Saturday, November 19, 2005 - 05:25 pm: |
I just got the Motorola DVR/PVR box with Cable One, and the Atlas DVR/PVR remote. I can't get the remote to work with my 20" Durabrand BH2004D tv. There's codes listed for Durabrand for the remote, but none works. |
| Posted on Tuesday, November 29, 2005 - 02:28 pm: |
FWIW, I got my Durabrand BH2004D to work with my DirecTV DVR remote by using the Code Search function. I recently moved and could not locate my remote for the Durabrand, so I hoped to operate it with the new DirecTV controller. I had been unsuccessful getting the Durabrand to work with a Phillips universal and after reading this thread I did not think I would be able to get the DirecTV controller to work either. There were no codes listed for either the Durabrand or for an Orion, which I had sitting next to the Durabrand. I was able to use the Phillips universal to operate the Orion, so I gave up on the Durabrand and decided to try to program the DirecTV controller for the Orion using a program search. As I progressed through the codes to try to find a code for the Orion, the Durabrand serendipidously responded. :-) Now the Phillips universal operates the Orion and the DirecTV controller is operating my (larger) Durabrand.
| Posted on Wednesday, December 07, 2005 - 08:34 pm: |
I would like to know how to program my tv to get all the chanels. I can't understand the instructions. Please help me, I just bought it yesterday, it is a 13 inch, the remote says HYF-23A |
no import crap Unregistered guest |
| Posted on Wednesday, December 21, 2005 - 06:23 pm: |
I recently inherited a BH2004D Durabrand tv. I've had all the problems mentioned; remote and the problem changing to two digit channels. first of all thanks for all the answers from everyone, boy did it save me the headaches But one thing it is not just crap chinese tvs, but all the crap coming in from china, our gov't and big business has and will continue to screw us over until we quit buying this crap and demand products made in the USA. |
| Posted on Thursday, December 22, 2005 - 06:51 pm: |
USE CODES FOR FUNAI I found one that worked for the Duraband 13inch set I lost the remote for. Good luck to all. 1038, 1046, 1047, 1189 |
| Posted on Monday, December 26, 2005 - 10:43 pm: |
i have a 13" durabrand tv and i have lost the remote. without the remote i cannot watch my dvd player. what is the code of durabrand for a uni500 remote. i would really appreate that, thanx. |
DurabrandUserToo Unregistered guest |
| Posted on Tuesday, December 27, 2005 - 05:41 pm: |
Orion Code 0463 Worked for me too... |
DexterFUN STUFF Unregistered guest |
| Posted on Wednesday, December 28, 2005 - 07:20 pm: |
Just so you are all aware of this fact ... the codes you are all describing are dependant on the modle of the universal remote you are using most universal remotes have a proprietary listing of the codes for thier own use so you are are better off to spend the extra 5 bucks to buy a universal remote with the code search opetion |
SamFreeman Unregistered guest |
| Posted on Friday, January 06, 2006 - 12:32 am: |
The code for Durabrand is 096 |
New member Username: Markotaing
Brookings,
South Dakota
Post Number: 1 Registered: Jan-06
| Posted on Wednesday, January 18, 2006 - 09:41 am: |
I have a P.O.S. Durabrand bh2004d and the stupid thing gets a big black square right in the middle of the screen. It will go away for a little while if I channel up or down but it returns for no reason. Could this be in the t.v. or could it be a weak cable signal? |
twistedjester Unregistered guest |
| Posted on Saturday, January 28, 2006 - 11:48 pm: |
27" Durabrand T.V. code 0171 worked for me. In the code list look for Funai. |
| Posted on Monday, January 30, 2006 - 04:45 pm: |
I'm been having the same problem. I have a 19" DBTV1020 and I can't figure out the code with a Radio shack universal 5-in-1 remote. I know that there's a search option, but I lost the remote instructions... Does anybody know how to perform the search function on a universal remote? |
gladysfriday Unregistered guest |
| Posted on Wednesday, February 01, 2006 - 12:17 pm: |
I have a 13" Durabrand Tv. Was looking for a very simple universal remote for my aging mother, so I found a Sony RM-EZ2 Universal Remote that seemed suitable. (Note: Durabrand was not on the code list, but for $10.00, took my chances anyways because it did have a search function.) I tried using the search function with no luck after searching approx. 200 codes. This remote uses three digit codes and only lists 75, from 001 to 075, so I assumed after searching for so long I had to have gone through the list at least twice. Then I turned the TV to Channel 3 and tried the search function again and was successful after less than 10 codes. I don't know if this had any relevance or if it was just fluke, but thought it was worth mentioning. I'm sorry I don't know what that code was because there is no display, but the search funtion did work....on Channel 3. |
| Posted on Monday, February 06, 2006 - 03:07 pm: |
I used code 107 for my Durabrand BH2004D. However this code only worked on my old RCA universal remote, and not the Dish network remote. Most newer universal remotes don't seem to work with mine. The only reason I want a remote is to put my tv into Video mode (The tv is crap when it comes to watching dvds from my dvd player, since the volume is too low even when you turn it up, then when I switch back to tv, the volume would be really high) Someone please list 3 digit codes, since I only have Dish network and not DirectTV.
Tankerbot Unregistered guest |
| Posted on Monday, February 06, 2006 - 07:09 pm: |
I found a very interesting code that the menufacturer of the BH2004D (Durabrand 19' TV). I accidently discovered it while trying to get the dish network universal remote to work with it. The code is: 683 Please note that this code has only been tested with the Dish Network 322 Universal remote. Other Dish network based universal remotes should also work. Expiremt with the button and and you will end up end some type of special setup mode that you can actually change advanced setting that arn't in the standard setup menu. Removing the black screen (shows up when there is only static) is one example. You can even mess with the Horizantal position of the screen etc. Experiment with it with care, since there is over 40 different settings and if you change them and forget what the orgenal settings were, you could end up with a very expensive paper wieght (lol). |
| Posted on Saturday, February 25, 2006 - 09:34 pm: |
I have the Time Warner Cable Digital Cable box and it comes with a universal remote. Does anyone have any experience with any code that might work for this remote? Alos I need to play a VCR and all I really need is the input button. does anyone else know how to get to watch my vcr and change inputs on this televison? |
New member Username: Tcancergirl
Post Number: 1 Registered: Aug-06
| Posted on Friday, August 11, 2006 - 02:34 pm: |
I bought a 19" Durabrand Model # DWT1905 for my kids and they lost their remote, this remote had a game button on it and what I would like to know is if I can use a universal remote with it so that they can play their PS2 or should I just buy another remote from the manufacturer. Any help will be greatly appreciated. tcancergirl69@yahoo.com |
New member Username: Inky13
Prescott Valley,
AZ
Post Number: 1 Registered: Sep-06
| Posted on Tuesday, September 05, 2006 - 04:12 pm: |
Greetings all: I have a Durabrand BH2004D TV. I bought it 2 years ago with my college roommates and ultimately it is now in my room, however, we lost the remote. I've bought a few universal remotes and heavily researched the forums about the issue at hand with no success. I currently have the URC-3220 remote. I've thrown in every code that I can, used its search function, used the codes on this forum, as well as others, and the codes provided at the mfg's websites. Shall I give up and pay the $40 for a replacement or do any of you know of a code/remote that will work? Thanks. |
New member Username: Ballin16
Post Number: 1 Registered: Oct-06
| Posted on Saturday, October 14, 2006 - 03:39 pm: |
does any1 know how to put durabrand BH2004D on video so i could use my ps2, i dont have the remote. |
New member Username: Luis2144
Concord,
Califaz
Usa
Post Number: 1 Registered: Dec-06
| Posted on Sunday, December 03, 2006 - 03:26 pm: |
i have a durabrand t.v. and i cant find the code for remote control please i need alot of help my remote control is called Philips PM335 Universal Remote  |
New member Username: Opp123
Post Number: 1 Registered: Jan-07
| Posted on Thursday, January 04, 2007 - 11:32 pm: |
Code for dish network is 720. I found it under emerson |
New member Username: Mickel_001
Post Number: 1 Registered: Feb-07
| Posted on Sunday, February 25, 2007 - 09:32 pm: |
My 13" durabrand tv is making a buzzing noise help !?! |
New member Username: Jane_ii
Post Number: 1 Registered: Sep-07
| Posted on Friday, September 07, 2007 - 08:57 pm: |
I recently had a problem programming my 13" Durabrand TV to work with my Motorola satellite box. No luck. It can be done, I had a smart tech from Star Choice know it but I lost it. Anyway, I purchased a 4 in 1 universal remote for $12.99 at my local hardware store and voila, there is a code in there for my TV and I can control my VCR, DVD and satellite box with it too. You don't have to pay a huge price for a replacement remote. Best of luck. |
New member Username: Mariak
Post Number: 1 Registered: Mar-08
| Posted on Saturday, March 08, 2008 - 01:52 pm: |
I just got a rca universal remote for my durabrand tv tried everything cannot get it to work pls help thanks |
