I have a 36" Proscan Model PS36600YX1 The IR(infrared)controller wires are attached properly from the cable box sensor and the VCR sensor to the TV set and the guide + and the correct time have been enstalled.The problem is when the set is off, the cable box rolls the stations over preventing the TV guide to be installed. Does any one have a solution for this problem?
