Outlaw Audio LFM-1 and SVS PB2-ISD Subwoofers
The LFM-1 from Outlaw Audio is a stellar value performer – but it doesn’t stop there. It held its own against a much bigger, more expensive competitor under normal use loads. Producing an incredible (almost unbelievable) amount of tactile energy during home theater and music use, the LFM-1 had me constantly checking myself to see if I had mistakenly left the SVS subwoofer connected. That kind of frequency response and performance out of a package that is nearly 50% less in volume and about 40% lower in price is something to be acknowledged. The SVS subwoofer is a bit of an enigma. Not because of anything bad, but because the unit sounds incredible but has none of the space-saving characteristics commonly found on other units. Is it the lack of self-imposed space constraints that makes the sub sound so good? Or is there something else at work? Its performance can be described as flat and yes, even musical. I couldn’t find a serious limitation or flaw. [ Read Full Review @ Audioholics.com ] [ More Outlaw LFM-1 Reviews ] [ More SVS PB2-ISD Reviews ] |
