Home > Message Board > Product Reviews > HP Touchsmart IQ506 Review
+ Share | Create New Product Review | Reply | Edit
HP’s computer with touch screen looks great on first impression. Touchsmart IQ506 doesn’t occupy too much space on your desk because it doesn’t have a case and everything is located behind the monitor. Monitor is high quality and supports full HD. After watching a movie with it you are not going to like other monitors.
Touchsmart includes a TV card inside and it’s easy to use with the remote control. You can use your finger as a mouse on the screen but your finger doesn’t have a right click so you need a mouse sometimes. It is also possible to write or paint something with your hand. Software that comes with the product allows you to play video, display photos etc.
A wireless keyboard and mouse are also in the box. Using another monitor is an option with the s-video out. If a HDMI port had been on it, it could be absolute perfect. Anyways Touchsmart IQ506 is a great entertainment center.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Product Reviews > HP Touchsmart IQ506 Review [ « Previous ] [ Next » ]
