Home > Message Board > Radio > Free Satellite Radio!!!!!!!!!!!!!!
Author Thread: Free Satellite Radio!!!!!!!!!!!!!!
Username: Cybermaster
Post Number: 8
Hello there,
XM or Sirius require subscription. However, some radio sations from satellites do not have encryption and therefore can be directly picked up with a satellite radio antenna. Does anyone know what antenna and/or equipment can be used to get the free unencrypted radio sations. Please post your kind comments here. Thanks.
Username: Ryersonresurrected
CANADA
Charlatan...
Post Number: 854
Gee, I'm interested in this 2.... and can we hack it ;)?
Username: Leew
XXXX!!WWWW, Yokosuka, ...
Holla Back Y...
Post Number: 1345
You have to get receiver and antenna for "S-Band" 2310-2690 MHz frequency. The 2310-2360 MHz portion is used for XM and Sirius Radio. Use Google for searching! As I know you can get a radio scanner for that. It will cost you around $500 USD. Just remember about the frequency!
Username: Thx_3417
Bournemouth ...
Post Number: 2927
LOL
What would you know about radio scanners? What do you work for the CIA as a double agent in the KGB I think your undercover part on the forums is genius?
Username: Leew
Holla Back Y...
Post Number: 1350
No,I am from a Tamplier Orden!Upload
Username: Illuminator
Post Number: 5000
Does anyone else see the conflicting logic here?
How can you make the first statement if you don't know how?
Username: Durski
Post Number: 111
im confused
Username: Project6
Post Number: 14654
Yes you are...and I think everyone else.
Los Angeles, CA
Post Number: 18640
i can't believe no one has figured out a way to hack sattelite radio.
Username: Project6
Post Number: 15190
Why bother?
Username: James1115
Use a simple...
Post Number: 10613
exactly for $10/month its peanuts. now if you hack cell phone cervice or satelite tellevision then thats worth looking at.
A pic is worth
1000 posts!!
Post Number: 16887
"exactly for $10/month its peanuts. now if you hack cell phone cervice or satelite tellevision then thats worth looking at."
Take a look at all the traffic in our sat section and you'll see where all the hacking is lol.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Radio > Free Satellite Radio!!!!!!!!!!!!!! [ « Previous ] [ Next » ]
