Thread: Chopped & screwed music, redux. |
New member Username: Mr_graham
The Jigga,
MA
United States
Post Number: 1 Registered: Jun-09
| Posted on Saturday, June 27, 2009 - 10:08 pm: |
Hi there, Thanks to a Google search, I came across this thread: http://forum.ecoustics.com/bbs/messages/289508/429578.html ...& so I just thought I'd share some of the stuff I've been making for the past 2-3 years with people here, since it seems like there might actually be some interest...! Long story short: if you drop by http://dotdotcomdotcomcom.com/Music.html you'll find a handful of mixes I've made (under the name xdonricklesx), featuring chopped & screwed versions of songs by the likes of: White Stripes Radiohead TV on the Radio Cat Power Shellac Big Black Franz Ferdinand Chris DeBurgh M83 Ratatat/Knife DJ Shadow/Keane UNKLE David Bowie Sade Elton John Roxy Music Blonde Redhead Madonna Chromeo Chromatics Killers ...& lots more. All done using 2 turntables (Numark, lowest-caliber), 1 mixer (Numark, then Korg). When possible I use 7"s or 45rpm records & play/record at 33rpm. Otherwise I drop the speed (not the pitch) using Audacity. Any comments (constructive, ideally) are welcomed, as are any questions (no need to be constructive). Hope you dig it! xdonx |
