Home > Message Board > Music > DTS Audio CDs
Author Thread: DTS Audio CDs
Username: Chotto
Can Anybody tell me how to listin to Audio CDs which are Digital (DTS) on computer. I know It will require some software or some codec. Which one I need.
thanks
Relevant Product Info
Username: Project6
Post Number: 14829
Can your PC read DVD's?
Username: Chotto
Oh yes. I have Sony DVD ROM
Username: Project6
Post Number: 14840
DTS encoded discs are usually on DVD, if your PC has a DVD player, you should be good to go. If the audio does not play, try downloading the AC3 codec...it's free.
Los Angeles, CA
Post Number: 18639
i have a dts encoded music on a regular cd berny. i need my dvd player to play it though.
Username: Project6
Post Number: 15162
Cool stuff.
Los Angeles, CA
Post Number: 18698
yeah it has sound effects from the movie twister and jumaji. its insanely clean. that is if you have the ht setup.
Username: Chotto
Here is another discription:-
How to listen 5.1:-
http://www.5dot1.com/how_to_listen_in_5_1.html
Another codec pack to listen to 5.1:-
http://www.cccp-project.net/
(Combined Community Codec Pack)
Comes with both the Codec required to play as well as Media Player Classic
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Music > DTS Audio CDs [ « Previous ] [ Next » ]
