Thread: "Under Siege" (1992) a JBL THX late night showing |
Gold Member Username: Thx_3417
Bournemouth ...
Post Number: 4509 Registered: May-05
| Posted on Saturday, September 08, 2007 - 12:11 am: |
 Well I couldn’t resist in running a very late night JBL THX showing of “Under Siege” (1992) I’m still impressed with the Dolby stereo 5.1, mix knocked my soaks off. Split-surrounds use was played back with centre back surround and performed magical plenty of side surround usage with atmosphere sounds and directional voice sounds over intercoms practically when (Gary Busey) character “Cmdr. Krill” walks though the corridors there’s a panned sound slightly on the right front and alongside the right sidewall surrounds.
I made a few audio compensations via lowering the LCR while boosting the LF in LCR and boosting the HF in the centre channel kept the action playing while maintaining clear dialogue intelligibility, Foley with hand to hand combat was handled with comfortable ease as “Casey Ryback” played by (Steven Seagal) disposes each bad guy with per-v-erted use of methods whether it be, explosives or cooking knifes.
LFE.1 supported the mix without overwhelming nor, bringing too much attention to itself was impacting during the helicopter explosion.
Gold Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 9949 Registered: Jun-06
| Posted on Saturday, September 08, 2007 - 12:23 pm: |
Now all you need is HD big screen. Is that in the works? |
Bournemouth ...
Post Number: 4510 Registered: May-05
| Posted on Saturday, September 08, 2007 - 05:06 pm: |
No I’m not interested the screens are far too small. A video projector is different kittle of fish entirely. |
A pic is worth
1000 posts!!
Post Number: 9962 Registered: Jun-06
| Posted on Saturday, September 08, 2007 - 06:19 pm: |
Ooooooo I want a projector so bad. Gotta scrap together the funds tho first. I have the perfect wall for it too! |
Bournemouth ...
Post Number: 4515 Registered: May-05
| Posted on Saturday, September 08, 2007 - 07:00 pm: |
No that’s where it’s wrong. You need a good flat wall area to work with yes. Then you need to build a platform for the matching loudspeakers to rest on and then place the screen up covering the loudspeakers from view so that the sound becomes transparent with the image therefore making seem real. You can go extra further by constructing a THX baffle wall and fit all the matching loudspeakers into it, making sure to absorb the inside of the THX baffle wall on the front wall and the front or rather the opposite side so that you have to parts absorbed. Then you need to cover the front part with high frequency absorbent material to prevent reflections bouncing off the perforated screen and back onto the untreated surface where the sound will have a shape tinny sound. So there’s a few parts that needs to be done. Its not rocket science its real easy. Decide on what materials you want to use cinemas use plasterboard but you can use the same or use a thinner MFD. Cutting the holes for size of each loudspeaker and planning it for the wildest possible stereo separation needs close attention paid towards it. The loudspeakers should be placed around 1/3 of the screen height. Sub bass is fitted below the centre channel in the same THX baffle wall. |
A pic is worth
1000 posts!!
Post Number: 9990 Registered: Jun-06
| Posted on Sunday, September 09, 2007 - 11:40 am: |
I'm thinking screen instead of wall. Projector would be about 12' from the screen. I'm hoping I can get a 6'-9' image size. Entry level projectors are under $1000 and I would be selling my Mitsubushi widescreen HD tv to offset the cost so it wouldn't be that bad. Maybe $500 out of pocket? It's my next step. |
New member Username: Jblsince1989
Post Number: 2 Registered: Mar-08
| Posted on Wednesday, March 26, 2008 - 10:58 am: |
Now this one still rocks the house plenty of cool action to go around. |
Platinum Member Username: Project6
Post Number: 15582 Registered: Dec-03
| Posted on Saturday, March 29, 2008 - 11:55 am: |
Too bad, Steven Seagal got fat and bald. I am surprised he still makes direct to DVD movies. |
Gold Member Username: John_s
Columbus,
Ohio
US
Post Number: 2215 Registered: Feb-04
| Posted on Sunday, March 30, 2008 - 01:00 pm: |
The best thing about Executive Decision is that Seagal's character gets killed half way through the movie. After that it's a great movie. |
Post Number: 15612 Registered: Dec-03
| Posted on Sunday, March 30, 2008 - 01:14 pm: |
LOL!!!
Platinum Member Username: Bestmankind
Http://www.rdaudio.net...
Post Number: 19755 Registered: Oct-05
| Posted on Monday, March 31, 2008 - 11:53 am: |
yeah i never liked seagal. |
