Home > Message Board > Movies > Howto: Rip DVD to Zune WMV, video to ...
Author Thread: Howto: Rip DVD to Zune WMV, video to Zune
Username: Zunevpod
1) Convert DVD to Zune WMV, WMA, MP4, MP3
2) Convert video and audio files to Zune WMV, MP4, WMA, MP3
The guide describes how to directly convert DVD, movie, music files to Zune video (WMV, MP4, H.264) or Zune audio (WMA, MP3, AAC) step by step. The program is more powerful than other Zune converter software, because it supports encoding to WMV and WMA playable on Zune without converting using Zune software again.
--- How to convert DVD to Zune WMV, WMA, etc.
1. Download DVD to Zune Converter from http://www.soft29.com/download/dvd_video/dvd-to-zune-converter-44744.exe and run it.
2.Click "Add DVD Folder..." in the File menu or directly click the "DVD" button in the main interface, then select your DVD-ROM in the pop-up window and press the "OK" button.
3. All files from DVD are loaded. If you only want to convert certain chapter(s), press "Show Chapters" button on the main interface and then check the chapter(s).
4. Select the target output format in "Profile" combo-box on the interface. Here WMV is recommended because Zune natively plays the format. If you choose MP4, zune Software will need to transcode it to WMV again, that waste a lot of time.
Tip: The software can also extract audio from DVD and save as Zune audio WMA.
5. After selecting "Zune WMV" as the output format, the right panel will show Zune WMV settings. By clicking certain setting(s), you may specify it. We suggest you to keep the default settings.
Tip: It supports clip or segment conversion. You can convert any clip or segment by setting the start point and duration at will. For example, you want to rip a clip from 00:03:20 to 00:08:00 please click "Start time" to set the starting time 00:03:20 and click "Duration" to specify the length 00:04:40.
Tip: Zune video size: 320x240
Tip: Zune video must be WMV with wma audio.
6. There are other options on the interface you can adjust.
>> In 'Zoom' section, you can find four options. 'Letterbox', 'medium', and 'pan scan' will convert 16:9 format to 4:3 format. The Full option does not correct the aspect ratio. If you have a 4:3 DVD, use the Full option.
>> In the 'Split' drop list, you may select the size of the volumes that you would like to generate.
>> Select the output folder by clicking the "Browse..." button or directly enter a path in "Destination" box.
7. Press the "Encode" button to start converting. You would see the info "Completed" in the status column after a successful conversion.
8. After the files are successfully ripped, you may transfer to your Zune with Zune Software.
--- How to convert video and audio files to Zune WMV, WMA, etc.
1. Download Zune Video Converter at http://www.soft29.com/download/dvd_video/zune-video-converter-44744.exe to install and run it.
2. Load the file(s): Add the video or audio files you would like to convert by clicking the "Add" button in the main interface or choose "Add" in the "File" menu.
3. Highlight the file(s) you'd like to convert, select the target output format from "Profile" combo-box.
Tip: It supports clip or segment conversion. You can convert any clip or segment by setting the start point and duration at will. For example, you want to rip a clip from 00:02:20 to 00:07:00, please click "Start time" to set the starting time 00:02:20 and click "Duration" to specify the length 00:04:40. For sync problem, you may lower down the video bit rate to have a try. You can also try to solve it by adjusting the frame rate.
4. Finally, press the "Encode" button to begin to convert.
5. Drag the converted Zune video/audio files to Zune software and sync to your Zune player.
Relevant Product Info
Username: Mikeok
Do you know I see dvd to zune converter, convert dvd to zune -- ipod zune psp video converter software released in a website ?
Username: Zunevpod
Thanks for strange posting.
Username: Peony
I just like to use aimersoft zune converter suite, it can easily convert DVD to Zune video and audio formats, including DVD to WMV, DVD to MPEG-4, and DVD to WMA, AAC and MP3 with great quality, and has many practical features such as customizing file size, DVD movie trimming, DVD video crop, subtitle selection, audio track selection and so forth.that's reallly nice, and you can check it out here for free:
http://www.aimersoft.com/zune-converter-suite.html
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Movies > Howto: Rip DVD to Zune WMV, video to ... [ « Previous ] [ Next » ]
