Thread: DVD Burning Help |
Silver Member Username: Dloweman
Post Number: 127 Registered: Nov-04
| Posted on Wednesday, August 10, 2005 - 09:36 am: |
My Brother just got a new computer with a dvd burner and was wondering what he needs to make use of it? Is there a special software package he needs? If so, what do you guys recommend. He well be mainly backuping some of his dvds like LOTR series. Thankd |
UnoDenero Unregistered guest |
| Posted on Friday, August 12, 2005 - 11:28 am: |
i like using DVD Fab Gold or Platinum....the program automatically splits it for you if you want and rips the DVD pretty fast too and then I use Nero to burn |
guest098387509275098 Unregistered guest |
| Posted on Sunday, February 19, 2006 - 02:23 pm: |
I have a new digital research 16x dual layer dvd + - burner that will only burn to dvd + media, Any suggestions. |
| Posted on Sunday, March 05, 2006 - 02:29 am: |
Forget buying any DVD copy software. The best software for that is DVD Shrink. Totally free and removes encrypting. It also uses Nero to burn. |
tomcsquirt Unregistered guest |
| Posted on Sunday, March 05, 2006 - 06:04 pm: |
where do u get dvd shrink free? the version I had would not beat copyright on new dvd's |
New member Username: Weezelb
San Jose,
CA
Post Number: 7 Registered: Sep-05
| Posted on Sunday, March 19, 2006 - 02:32 pm: |
Absolutely best & easiest software to use is AnyDVD for breaking the encryption and CloneDVD for the shrinking, remvoing extras, and burning. Average for 1 DVD to completion is about 40-minutes, longer movies of 120minutes or longer will take about an hour on. http://www.slysoft.com/en/anydvd.html Simple, just point and click with an easy to naviagate menu & great help area. |
New member Username: Talib
Post Number: 1 Registered: Apr-06
| Posted on Sunday, April 09, 2006 - 04:45 pm: |
Is that possible to Burn a 3 or maybe 2 Indian movies in a single DVD disk, one Indian movie = 3 hurs it means 3X3=9 hurs, I have saw a DVD like that, can you guys tell me the trick, waiting for your help |
