Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through April 16, 2004 > Advice on some 5" speakers for my doo...
Author Thread: Advice on some 5" speakers for my doors this time! +Some other misc stuff.
Username: Doctorsonic
Post Number: 7
Okay, I am getting two 12" Kicker VR Comp subs, and a JBL 600W amp... I was wondering what kind of 5" speakers I should get for my two front doors?
I went to etronics and this was the selection they had:
Audiobahn AN5000 5" 2-Way Coaxial Speaker (PAIR) = 69.99
HiFonics HCX52 5" 2-Way Coaxial Speakers (Pair) = 49.99
Legacy LS5520M 5" 2Way W Motorola Tweeters (PAIR) = 39.99
Which ones would you suggest?
Oh yeah, I drive a 1985 Jeep Wagoneer (same thing as a Cherokee), V6. I dunno if anyone wanted to know that or not, but... Yeah.
Anyway, thanks for the info!
Oh, where can I find a decent box for a good price for the two 12" Kicker VR Comps? It doesn't have to be a dual box, they can be seperate, so long as the price is okay. I couldn't find any Kicker boxes at etronics.com, only found like three and they were all 200.00+... Which is, as you know, way too much for a box!!
Or does the box brand not have to be the same as the subs? Anyuway, link me! =)
Username: Glasswolf
Post Number: 562
www.thezeb.com
look at CDT speakers.
much better than anything you listed from etronics.
as for the box.. build your own.
best results that way.
Post Number: 8
What would be the specs I'd use and the materials (ie type of wood, if any other things are needed other than the tools, of course)? Two 12" Kicker VR Comp subs, is what it's for.
Username: Glasswolf
Post Number: 571
specs are available from www.kicker.com
Post Number: 9
I'm a complete dolt... Can you provide a direct link please?
And also a couple links to some cheap boxes? In case I decide not to tempt fate... I'd probably mess the box up if I made it myself. =\
:P
Thanks for all your help!!
Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through April 16, 2004 > Advice on some 5" speakers for my doo... [ « Previous ] [ Next » ]
