Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2004 > Diamond audio amp advice?
Author Thread: Diamond audio amp advice?
Username: Cisco
Im planning to purchase 2 12"-tdx dual 4ohm diamond woofers for my car? What type of diamond amp should I run these woofers?
smart-as$
a good one
Username: 01gsxr
Post Number: 7
get 2 D7 7402 each amp has 1600 wats rms at 4ohms. There verry nice amps witch will throw you back about 1000 a piece.There Thd is 0.02 nice!!!!! Your $hit will bang and look hot to.
A friend of mine bought two TDX 12's and a U.S. Amps USA-2000 at audioperfect.com. They sound awesome! And they guaranteed service for the length of the factory warranty period.
http://www.audioperfect.com/shop/catalog/product_info.php?cPath=3_25&products_id =104
Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2004 > Diamond audio amp advice? [ « Previous ] [ Next » ]
