Thread: Amp to stock deck HELP OUT!!!! Glass Derek anyone. |
New member Username: Tikolx333
Post Number: 87 Registered: 12-2003
| Posted on Monday, January 05, 2004 - 03:09 pm: |
Hey my Jeep engine block cracked from the cold so now I need to move my system into another car that has a stock deck. How do I do it? I have a Lexus LX 450 97 and it has a Lexus Premium Sound. So it has a stock 8" sub in it and I need to wire a Kicker 1200 amp. How do I do it where do I plug in the RCA's and the remote wire? Please be specific. Thank you. |
Post Number: 88 Registered: 12-2003
| Posted on Tuesday, January 06, 2004 - 01:46 am: |
Ok so I use the speaker output wires to plug in the amp whre do I plug them in though there is left - left + right - right+ what do I cannect those too and my stock sytem has a sub can I tap into that? |
New member Username: Glasswolf
Post Number: 530 Registered: 12-2003
| Posted on Tuesday, January 06, 2004 - 08:32 am: |
what do you have and what do you plan to move to the Lexus? do you plan to keep the stock system at all?
Post Number: 89 Registered: 12-2003
| Posted on Tuesday, January 06, 2004 - 09:39 am: |
I have a Kicker 1200 with 3 xtant 12" I want to keep the stock deck and speakers but replace the stock 8" subs with the 3 12's. |
Post Number: 90 Registered: 12-2003
| Posted on Wednesday, January 07, 2004 - 03:00 am: |
anyone know come one now help out |
Post Number: 540 Registered: 12-2003
| Posted on Wednesday, January 07, 2004 - 06:44 am: |
you need to use high level inputs on the amp, not the RCA lines. remote will need to go to an ignition-hot line at the fuse box.
