Thread: Kicker KX300.4 Pushing Speakers |
| Posted on Monday, January 05, 2004 - 04:53 am: |
I was looking to use this amplifier to push some infinity kappa speakers. Now its 38x4 @ 4 ohm, and 75x4 @ 2 ohm. I would need 75 watts, so my two questions are is this a good amplifier for sound quality and also is it possible to run the speakers at 2 ohm to get the 75 watts they need or do I need to choose another amplifier? |
New member Username: Glasswolf
Post Number: 528 Registered: 12-2003
| Posted on Monday, January 05, 2004 - 05:25 am: |
great amp try it at 4 Ohms and see how it does first. you may be surprised at how loud it gets. remember double the power is only a +3dB gain in volume, so it's not like the speakers would be twice as loud going from ~40 to ~75 watts wach. if you want 75W each, get two of those amps, and bridge them to two channels each. one amp for fronts, one for rears. alternative is the JL 300/4 I think that's 75 x 4
