Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2004 > Memory wire?????
Author Thread: Memory wire?????
im getting sick of cahnging the settings everytime i get in my car. i have an AIWA deck. I think the memory wire is brown but i dont have a brown wire running from the deck, i only have one running from the factory harnest or whatever. does any1 know how i can fix this.
P.S. i know this question is stupid but i dont know a lot about music. :-)
Username: Glasswolf
Post Number: 481
wrong section. this is amplifiers, not head units.
you don't match colors, by the way.
the memory wire from the radio is most likely yellow.
+12 ignition is likely red
ground is black
blue is remote/power antenna
illumination is usually orange
Username: Tikolx333
Post Number: 83
what does illumination do? my illumination wire isnt used but my deck works fine. and my mute wire isnt plugged in and deck works fine?
Username: Glasswolf
Post Number: 484
illumination usually dims the display when your head lights are on.
if the radio has a separate "dimmer control" wire, that gives a variable illumination when you brighten or dim the dash display.
mute is for a cell phone cradle, or similar, to mute the stereo when the phone rings.
Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2004 > Memory wire????? [ « Previous ] [ Next » ]
