Thread: Amp setup: need help |
hersheys Unregistered guest |
| Posted on Saturday, September 18, 2004 - 01:36 am: |
i have a audiobahn a6601q amp with info: 75 watts RMS x 6 at 4 ohms 105 watts RMS x 6 at 2 ohms 210 watts RMS x 3 bridged output 3-, 4-, 5-, or 6-channel output Tri-Way capable MOSFET power supplies High-pass/low-pass crossovers, (50-500 Hz, 18 dB/octave) Selectable 18 dB bass boost at 50 Hz 3 sets of preamp inputs Cooling fan Cobalt blue illumination Digital voltmeter i am trying to hook up 2 audiobahn subs but i have never hooked up subs to a 6 channel amp can some1 describe how i would be able to hook up the wiring and to which channels to hook up to because right now im getting a little bass out of the subs but also sound, i want to eliminate the sound from the subs and only have bass, thnx in advance |
Silver Member Username: Koz1031
Monticello,
In
United states
Post Number: 116 Registered: Jul-04
| Posted on Saturday, September 18, 2004 - 05:41 am: |
svc or dvc? just bridge any 2 channels to the subs this will give you 210 watts. then you will have either 2 channels left or 1 channel bridged. |
