Thread: Quesion about head unit |
Bronze Member Username: Jarryd2018
Post Number: 24 Registered: Sep-04
| Posted on Friday, September 17, 2004 - 05:16 pm: |
i have a explorer and it has the controls for the stock cd player in the backseat and i was wondering if there was any way that it would still work if i got an alpine head unit |
Bronze Member Username: Cruxis
PA
Post Number: 17 Registered: Aug-04
| Posted on Friday, September 17, 2004 - 09:11 pm: |
It will most likely bybass those controls, transfering them to where the head unit is. |
New member Username: Noblemobile
Van Nuys,
CA
Post Number: 4 Registered: Sep-04
| Posted on Tuesday, September 28, 2004 - 06:25 pm: |
NOPE! you lose the controlls, no way around it, yet. |
Post Number: 39 Registered: Sep-04
| Posted on Tuesday, September 28, 2004 - 06:39 pm: |
will the air conditioner backseat controls bakc there work because they arent connected to the head unit
Van Nuys,
CA
Post Number: 7 Registered: Sep-04
| Posted on Tuesday, September 28, 2004 - 06:50 pm: |
Can't say I remember. Take the radio out & disconnect the two plugs in the radio & test it out. That radio doesn't require a code so you'll be fine disconnecting it. |
