Thread: JBL Power BPX500.1 Good/Bad? |
Bronze Member Username: Crappycarguy
Post Number: 26 Registered: Sep-04
| Posted on Thursday, September 16, 2004 - 08:43 pm: |
Would this be a good amp for 2 infiniy kappa perfects? And would I need the 4 ohm ones or the dual 4 ohm ones? |
Silver Member Username: A3forme
Post Number: 128 Registered: Sep-04
| Posted on Thursday, September 16, 2004 - 09:17 pm: |
No, I wouldn't use the BPX500, Maybe the GTO600.1 But preferably use the Kicker KX600.1! It'sunder rated and will work well with the Single 4ohm Perfects. |
Post Number: 27 Registered: Sep-04
| Posted on Thursday, September 16, 2004 - 09:54 pm: |
whats wrong with the bpx 500 the gto600.1 is better? |
Post Number: 129 Registered: Sep-04
| Posted on Thursday, September 16, 2004 - 10:29 pm: |
I don't think there's anything wrong with it, but I think you could do much better for the money. I'd take the Kicker KX600.1 or the MTX801d myself. If you go with this amp, you'll need the dual 4ohm subs. Will give about 325w per sub. |
