Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2004 > Best way to wire 4ohm dvc please help
Author Thread: Best way to wire 4ohm dvc please help
i have a kicker l7 15 with 4ohm dvc and a rf 851s amp. the amp is bridgable at 4ohms. what would be the best way to hook up my speaker to this amp? someone plese help
is there any way to use both vc and still have a 4ohm load?
Username: Glasswolf
Post Number: 464
yes. run the amp in stereo and put one coil on each channel.
asdnfashdhfdioasj
ok thnks
Username: Glasswolf
Post Number: 470
by the way, be sure to use a low pass filter for the sub, set to around 80Hz or so, and run the amp in mono mode if you have that option from the amp or head unit or crossover.
you want both coils to get the exact same power and signal.
be very careful balancing gains if you have separate ones for left and right channel.
it's slightly tricky to set up a DVC sub like this, but it's do-able.
Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2004 > Best way to wire 4ohm dvc please help [ « Previous ] [ Next » ]
