Home > Message Board > Car Audio > Amplifiers > Archive through September 18, 2004 > Nedd some quick advice please!
Author Thread: Nedd some quick advice please!
Username: Choppersinc
Post Number: 8
I have a 340 watt two channel running two 220 watt pioneers and I have a 300 watt two chaneel that I'm running a 10" sub bridged I jumped the remote and power wire but hooked the ground seperat is this ok to do or will I loose power because I jumped the power and remote wires? all I want to know is what do I need to account for the fuse under the hood bigger? or what?
Post:
Username: Enter username if you have an account OR your name
Password: Enter your account password OR leave blank if unregistered
E-mail: Enter your e-mail address (optional)
Options: Post as "Anonymous"
Enable HTML code in message
Action:
Username: A3forme
Post Number: 110
Are you just trying to hook it up so it works, or are you trying to do it the right way?
helpme
What amp would you use to run 2 Orion 10" H2's 2 ohm
Pheonix Gold Xenon 12000.1
Hifonics Brutus? the 1000 watt or 16000 watt or the 2200 watt.
Those are hungry amps.....I don't think any of them will work. The are 2000w RMS subs.
You'll need something like this at least!!!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64572%26item%3D5721086563 %26
Or (2)Kicker KX1200.1, One to each sub. $369 + shipping. I would advise some differen't subs. They are killer, but need a lot of power. You're gonna spend a fortun on amps.
Home > Message Board > Car Audio > Amplifiers > Archive through September 18, 2004 > Nedd some quick advice please! [ « Previous ] [ Next » ]
