Thread: No power getting to AMP,aghh please help |
Unregistered guest |
| Posted on Thursday, September 16, 2004 - 08:06 am: |
Hi, I just purchased a car, it has a BOSS BA-800 4ch mosfet bridgeable, 4x200w, 800w MAX, amplifier. The head unit switches on with power, there is absoulutely no sound, I checked the cabeling and rewired the end points, it all seems to be in order, I cannot get the power lights to switch on the amp. What am I doing wrong?? Is there a power switch, I can't find one??, please help, thanks |
New member Username: Metall1cfan
Post Number: 7 Registered: Sep-04
| Posted on Thursday, September 16, 2004 - 11:32 am: |
BOSS equipment will only work with other BOSS equipment...or so I was told |
| Posted on Thursday, September 16, 2004 - 01:33 pm: |
Yes, but why can I not get the power led to light up or the fans to run, I am sure it is a power problem |
Bronze Member Username: Fishy
Tamarac,
FL
Post Number: 56 Registered: Sep-04
| Posted on Thursday, September 16, 2004 - 03:51 pm: |
If you have a multi meter check for voltage at the power lead and at the remote turn on. And you of course have checked the fuse(s) right? -Fishy |
Bronze Member Username: Allpro
Dacula,
Ga
United States
Post Number: 33 Registered: Sep-04
| Posted on Thursday, September 16, 2004 - 04:21 pm: |
check the ground. If the amp is not ground properly it will not power. |
| Posted on Friday, September 17, 2004 - 01:07 am: |
Checked all fuses, Checked all connections, including ground, I have not got a multimeter, so cannot check connectivity & power. I have not checked the remoted lead the whole length, if it is broken, will the amp power up??
Tamarac,
FL
Post Number: 62 Registered: Sep-04
| Posted on Friday, September 17, 2004 - 05:54 am: |
Umm.. this may sound stupid, but stick your nose to the amp and take a good wiff. Sometimes when an amp "fries" it leaves a distinctive burnt electronics smell. Oh and if you have a lil 12v lightbulb and socket you could check power with that or you can pick up an analog multimeter or cheap digital one for 15 or 20 bucks at Radio Shack. http://www.radioshack.com/category.asp?catalog%5Fname=CTLG&category%5Fname=CTLG% 5F011%5F008%5F002%5F000&Page=1&find=multimeter(keyword)&hp=search -Fishy |
| Posted on Saturday, September 18, 2004 - 10:24 am: |
OK, I checked power and it is connected, both active and ground, I connected a mulitmeter to the remote and ground and there was NO continuity. Is this strange? I also smelt the amp, there is no burnt electronics smell. I have run a second remote lead, this has had no effect. Any more suggestions?? |
Silver Member Username: Koz1031
Monticello,
In
United states
Post Number: 123 Registered: Jul-04
| Posted on Saturday, September 18, 2004 - 10:38 pm: |
Run a temp. remote wire from the fuse box. (make sure key is on. This will tell you if it's the remote wire. Amp shouldn't turn on without it. Amp is supposed to be suppling power to what? subs or fill? maybe those are fried. or simply not hooked up. Did you check fuses? Are you sure the h/u even works. Just cause it lights up means nothing. I didn't look up the h/u but is it a radio&cd player. have you tried both, as ant. may be disconnected from back of h/u. if also plays cd's try putting in a cd. did you check rca jacks? |
Tamarac,
FL
Post Number: 96 Registered: Sep-04
| Posted on Sunday, September 19, 2004 - 12:31 am: |
When you say "no continuity" do you mean no voltage when the head unit is on? If thats the case then your remote lead is definitely your problem. I don't know how recommended this is, but try taking a short piece of of wire(fused like koz said would be nice) and MOMENTARILY connect the remote input on your amp directly to the power lead and see if you can get any power lights to come on. If that doesn't work there's a problem with your amp. Whatever you do don't leave it connected that way or your amp will be be on ALL the time and will kill your battery fairly quickly. If jumping the remote input does work then you need to run your remote lead back to the h/u and make sure you have a good connection there. Measure the voltage at the h/u remote out if you can. It doesn't have to be a full 12v. I think most amps only need 5v+ to fire up. good luck -Fishy |
Monticello,
In
United states
Post Number: 136 Registered: Jul-04
| Posted on Sunday, September 19, 2004 - 07:01 am: |
did you check the inline fuse from the battery connection to the amp? Are the subs the only thing that is not working? |
| Posted on Monday, September 20, 2004 - 04:48 am: |
OK, thanks for the help, After checking that the amp works with attaching a small amount of lead from the power, direct to the remote, it fired up. I chased the remote lead back to the H/U. It seems to be incorrectly hooked up. I have now re-wired it and it works sometimes. I thnik I need to re-check my H/U wiring. Also there is now the problem that when the car is idiling slowly, the amp cuts out. Is this meant to happen with a 800W amp? Other than that it is all good thanks |
Monticello,
In
United states
Post Number: 139 Registered: Jul-04
| Posted on Monday, September 20, 2004 - 05:36 am: |
No it's not meant to happen. Probably underpowering the amp. Check the alternator. You probably need a bigger one with that big of an amp. What type of car you get? |
| Posted on Monday, September 20, 2004 - 10:54 am: |
Clarion amp instalation. I have 3 imputs on my Clarion amp. Earth, power and REM. If I connect the amp direct to the battery do i need to install a switch to turn the unit off or is there another way. |
Monticello,
In
United states
Post Number: 140 Registered: Jul-04
| Posted on Monday, September 20, 2004 - 08:42 pm: |
Earth=I imagine Ground Power= to the battery rem= remote to the blue wire on the back of the h/u. or to the fuse box. |
