Thread: NEED AMP HELP ASAP |
New member Username: Clipsed
East Haddam,
Connecticut
Post Number: 1 Registered: Sep-04
| Posted on Tuesday, September 14, 2004 - 07:24 pm: |
Right now I have four (4) Audiobahn Alum12Q's (1000W RMS) that have dual 6-ohms. I want to run a seperate mono amp for each one. Any Suggestions? Need Help ASAP. Thanks Guys.. -VM |
Silver Member Username: Southernrebel
Louisiana
Post Number: 170 Registered: Mar-04
| Posted on Tuesday, September 14, 2004 - 07:51 pm: |
it would be better to run 2 mono amps. something like 2 JBL BP1200.1's....it puts out ~1200watts at 2 and 1 ohm...if you wire a pair of subs in parrallel you would get a 1.5 ohm load, that amp would give each sub ~1100wrms. also, audiobahn isnt that good of a sub...they are know to fail (blow) and the SQ/SPL isnt up to par w/ their price range...just thought i'd let ya know. |
New member Username: Allpro
Dacula,
Ga
United States
Post Number: 8 Registered: Sep-04
| Posted on Wednesday, September 15, 2004 - 05:00 pm: |
Your Audiobahns should be fine. You can run 4 mono amps, but as Marshall said, you would be better served running 2 more powerfull amps mono(easier on yuor electrical system too). At Dual 6 in parrallel you will get a 1.5 ohm load. I can think of several amps that would pound those subs. Depends on budget...How much are you wanting to spend. And if you want 4 mono's, that would be awesome too. What kind of budget? |
East Haddam,
Connecticut
Post Number: 2 Registered: Sep-04
| Posted on Thursday, September 16, 2004 - 08:19 pm: |
Well, thanks for the advice guys. I'm Stillinterested in running 4 mono amps. im looking to spend as little as possible, but I'm flexible... |
