Home > Message Board > Car Audio > Amplifiers > Archive through September 18, 2004 > Question
Author Thread: Question
Username: Pdivvy5
CT
United States
Post Number: 69
Ok, i have a pair of 12 inch JL W0's, and they are 8 ohm subs. If i get the JBL 600.1 amp, how much wattage will each sub get if i wire them 8 ohms? Can they be wired this way? I think they are 150 RMS subs. Any help is great...
if you wire the subs parrallel you will have a 4 ohm load....and the subs will get ~150wrms each.
Username: Pdivvy5
CT
United States
Post Number: 70
but i heard that my subs are picky...and if you dont wire them to their specs they could blow...should i till wire them in parrallel?
Username: Southernrebel
Louisiana
Post Number: 177
yea...parrallel
Username: Pdivvy5
CT
United States
Post Number: 71
thanks man
Home > Message Board > Car Audio > Amplifiers > Archive through September 18, 2004 > Question [ « Previous ] [ Next » ]
