Thread: KnuKonceptz 8 or 4ga kit for Alpine 200w Amp? |
| Posted on Tuesday, September 14, 2004 - 02:41 pm: |
I just obtained an Alpine MRP-M350 to power a 10" 225w @ 4ohm. Should I pick the KnuKonceptz 8ga or 4ga? The 4 seems a little excessive for this application... any thoughts? Alpine manual says 8ga or better for power wire. All this is being hooked to an Alpine CDA-9827. |
New member Username: Wicked_sin
Post Number: 8 Registered: Aug-04
| Posted on Tuesday, September 14, 2004 - 02:57 pm: |
try this site below, it will help you out. http://www.the12volt.com/info/recwirsz.asp |
| Posted on Tuesday, September 14, 2004 - 03:26 pm: |
Excellent site. Thanks! |
Bronze Member Username: A3forme
Post Number: 59 Registered: Sep-04
| Posted on Tuesday, September 14, 2004 - 04:32 pm: |
8 gauge is fine for 200W amp |
Gold Member Username: Jonathan_f
GA
Post Number: 1619 Registered: May-04
| Posted on Wednesday, September 15, 2004 - 01:26 am: |
8 guage is plenty, but if you plan to upgrade or add another amp later, you'll be better off going ahead and getting 4 guage. |
