Home > Message Board > Car Audio > Amplifiers > Archive through September 18, 2004 > Help needed on amp selection
Author Thread: Help needed on amp selection
guy that needs help
i have 2 6.5 inch sony xplode speakers 220 watts max, 55 rms and 2 12 inch pioneer subs 500 watts max, 150 rms, all in the back of my car and i was wondering what amp i should buy, hopefull in the 200$ range (canadian), and i would also like to know all the specifics and details on what i need. Maybe someone can show me a good and very powerful amp that i could purchase at bestbuy.com so if ne one has time to help me it would be hugely appreciated. thank you
guy that needs help
i want an amp that will push my subs to there best performance
do you want it from best buy only??
guy that needs help
no it really doesn't matter but i am limited to not that many stores
Username: Fishy
Tamarac, FL
Post Number: 43
Need to know the impedance of those subs.
Are they 4 ohm, 8 ohm, dual 4 ohm voice coils, etc.
-Fishy
Username: Fishy
Tamarac, FL
Post Number: 44
Oh and what head unit do you have?
If all you care about is the bass you might get away with powering the 6 1/2's with your head unit.
-Fishy
guy that needs help
this is my sub info:
max powerl: 500w
nominal power: 150w
impedance: 4
sensitivity: 91 dB/W [1m]
frequency response: 20-4,000 Hz
Home > Message Board > Car Audio > Amplifiers > Archive through September 18, 2004 > Help needed on amp selection [ « Previous ] [ Next » ]
